enable avb
enable avb
Description
This command is a macro command that can be used to enable all AVB protocols globally on the switch. It is equivalent to issuing the following three commands:
enable mvrp
enable msrp
enable network-clock gptp
Syntax Description
avb Audio Video Bridging.
Default
Disabled.
Usage Guidelines
Use this command to enable all AVB protocols globally on the switch.
enable avb
This command was first available in ExtremeXOS 15.3.
Platform Availability
